Har alla Porsche 944S2 ABS?
- Falken
- Bilmodell: Porsche 944 S2 1990
Frågan lyder om alla Porsche 944S2 har ABS som standard?
Med vänlig hälsning Fredrik
- Bathory
Re: Har alla Porsche 944S2 ABS?
Nej det har dom inte
Porsche 911-82 (Såld)
Porsche 931-79 (skrotad)
Porsche 944-84 (Smälld)
Porsche 924-84 (såld)
Porsche 931-79 (Såld)
Porsche 924-80 (Skrotad)
Porsche 924-84 (Såld)
Sv: Re: Har alla Porsche 944S2 ABS?
Säker på det?Bathory wrote:Nej det har dom inte
Har för mig att alla 944.or fick det som standard 88 eller 89, men det kanske bara gäller svensksålda bilar.
- MacScott
- Årsmodell: 1989
Re: Sv: Re: Har alla Porsche 944S2 ABS?
Jag har en svensksåld turbo -89 och jag har ingen ABSErol wrote:Säker på det?Bathory wrote:Nej det har dom inte
//Christer
Efter att ha kollat lite mer noggrant hittade jag ABS ändå på min 951:a.
Det gäller kanske att ha mer kött på benen innan man ger sig in i ämnet och ska visa sig duktig.
// Christer
- Bilmodell: 924 -85 /931 -81
Snabbt googlat. Knappt läst texten själv.
944
For the 1987 model year, the 944 Motronic DME was updated, and newly incorporated anti-lock braking and air bags for increased safety. Because of the ABS system, the wheel offset changed to 52mm and Fuchs wheels were no longer an option.
For the 1987 model year, the 944 was updated to incorporate anti-lock braking and air bags for increased safety. Because of the ABS system, the wheel offset changed and Fuchs wheels were no longer an option.
951
The Turbo's front and rear brakes were borrowed from the Porsche 911, with Brembo 4-piston fixed calipers and 12" inch discs as ABS also came standard.
The Turbo S front brakes were borrowed from the Porsche 928 S4, with larger 4 piston fixed calipers and discs; rear brakes remained the same as a standard Turbo. ABS also came standard
The Turbo S front brakes were borrowed from the Porsche 928 S4, with larger Brembo GT 4-piston fixed calipers and 12" inch discs; rear Brembo brakes remained the same as a standard Turbo. ABS also came standard.
S
Dual safety air bags, limited-slip differential and ABS braking system were optional on the 944S.
Dual air bags were optional on the 944S, as was ABS.
S2
Dual air bags (left hand drive models), limited-slip differential and ABS were optional.
944
951
S
S2
Ah, så det var standard på turbon, men tillval på övriga bilar!Harpin wrote:Snabbt googlat. Knappt läst texten själv.
- [Bobo]
- Bilmodell: 931-81
Osäker på den där Googlingen dock... Jag har ingen airbag på min S2:a.Erol wrote:Ah, så det var standard på turbon, men tillval på övriga bilar!Harpin wrote:Snabbt googlat. Knappt läst texten själv.
Edit: Eller läser jag fel?
- Falken
Hur kan man se om bilen har ABS? Var sitter den där lådan?
Mvh Fredrik
Mvh Fredrik
- Karl Birgander
- Telefon: 0737168502
Boxen/ABS-enheten sitter i höger hjulhus.
Rakt bakom hjulet innanför innerskärmen.
Du ser också att det går en hel del bromsrör in i skärmen.
Sen bör du också ha en lampa i instrumentpanelen som slocknar när ABS är ok.
- Falken
Jag gjorde en liten check i bakluckan...
Porsche 944S2
Eng code 41
Lack LY7P/LY7P
Optionskoder
288 Headlight washers
424 Automatic heating control
454 Cruise control
490 Hifi sound system
494 Zusatzverstärker für Hi-Fi sound system
533 Larm
593 ABS låsningsfria bromsar
605 Strålkastare vertikalt ställbara
650 Sollucka
983 Läderklädsel bak och fram
Så då har man ABS....antar att det funkar så länge ABS lampan inte lyser.
Porsche 944S2
Eng code 41
Lack LY7P/LY7P
Optionskoder
454 Cruise control
533 Larm
650 Sollucka
- MattiasA
- Bilmodell: 944Turbo -90
hör du ett svagt surr när du rullar iväg efter att ha startat bilen ? Som jag förstått det är det ABS-enheten som startar/gör något självtest vid ca 10km/h.
/Mattias
/Mattias
Mattias Andersson
944 turbo-90
PCS 10746
944 turbo-90
PCS 10746
- Falken
OK, det skall jag se på vid tillfälle. Bromsarna skall genomgås och delar skiftas ut såsom skivor etc.
Just nu kan jag inte starta bilen...det är något fel eftersom bränslepumpen inte får ström. Pumpen är ok och ledningen dit är ok. Det är ledningarna till DME som strular (funkar inte även om jag skifta DME reläet) antingen ngn av givarna eller en kabel som är lös. Hoppas det löser sig.
- [Bobo]
- Bilmodell: 931-81
Kolla så att alla kablarna sitter som dom ska i "relähållaren".Falken wrote:OK, det skall jag se på vid tillfälle. Bromsarna skall genomgås och delar skiftas ut såsom skivor etc.
Patand drabbades av att en av "honorna" hade smitit ut bakvägen på 931:an när vi skulle ut och okynnesåka vid tillfälle...
Sv: Har alla Porsche 944S2 ABS?
Du har inte ett gammalt larm som spökar, de brukar bryta strömmen till pumpen.
- Falken
Enligt listan har bilen larm (kod 533). Är det bara att bygla de två kontakterna på larmet enligt Clark's garage? Vi lyckades starta bilen om vi mata bränslepumpen direkt.
