9P Caster block for Porsche 944 and 968
I'm producing set of aluminum caster blocks. Item is designed to fit Porsche 944 '85,5- including S and S2 and 968 models.
Item is produced from series 6000 alumium with maintenance free Hirschmann teflon/chrome spherical bearing. Bearing slackness is only 0.00-0,005mm. Bearing housing is without a seal so this item is ideal for summer use and of course for a racing car.
I will sell a pair from this first manufactured set for 140 euros. First pairs are out from surface finishing lab on next week so better pictures coming soon... Items are available in Black, Red, Blue and Grey.
Installation note: The powder coated shaft where the caster block is installed are usually painted so thick that little grinding with sand paper might be needed. Item can be installed with the car's original M10 fasteners.
I'm shipping the items from Finland so shipping cost for a pair will be 10 to 20 euros. Payment with wire transfer or Paypal.
You can contact me to info@9xx-parts.com.
These items can be bought trough Gustaf from Revline Racing too.
Br, Antti
- makkanftw
Re: 9P Caster block for Porsche 944 and 968
I'm guessing 924S only?ant771 wrote:Item is designed to fit Porsche 924, 944 and 968 models.
Brgds,
Marcus
You are partially right.. The caster block fits only to aluminum control arm. 924S has aluminum rear control arm but the front arm is steel. So caster blocks can't be used in any 924 models(unless it's with updated control arms).makkanftw wrote:I'm guessing 924S only?ant771 wrote:Item is designed to fit Porsche 924, 944 and 968 models.
Here's the first one..
I got some orders from Sweden and I'm waiting couple more...
You can order one pair in special price on next week only. After that I will sell these only in retail price.
Colors in stock now: Grey, Black and Red.
Br, Antti
Br, Antti
Antti's products are real nice, I have seen these in "live". Quality is absolutely great. Will get two pairs; one for my own 951 and a second pair for son's project 951.
Olli
-88 951 3.0L 16V
-88 951 3.0L 16V
Here's a picture of the first proto of an a-arm front mounting point spherical bearing assembly.
The proto unit in the picture has not the second phase machining or the surface finishing..
ps. sorry for continuing the thread in "säljes" section. I just got already two persons from Sweden interested in this item so I think there will be some others too?
Br, Antti
Br, Antti
I sell this a-arm bushing for 190 euros pair now. The retail price will be 220-250 euros pair.
One set includes two complete bushings with Hirschmann spherical bearings. Shipping to Sweden is 15 euros.
- Nahpets
What is the difference compared to delrin bushing?
- Henka_E
- Bilmodell: Porsche 944
A delrin bushing will never be able to handle the miss-alignment of the front suspension. No matter how you try and set caster, the front and rear pivot points of the control arm will never line up! Using spherical bearings at least at one end improves this.
På svenska och utförligare: Eftersom det är en total träskalle som designat alu bärarmarna så linjerar inte den främre och bakre bussningen i bärarmen - eller rättare sagt, axeln kring vilken armen roterar är olika i främre och bakre punkten. Detta medför att armen kärvar och man måste ha gummi för att ta snedställningen. Om man byter till delrin fram så styr man upp armen ännu mer - enda sättet då är att ha ledlager i bakre änden. Helst ska man ju ha det i båda ändrana, då är man säker på att bärarmen kan rotera fritt - kolla tex i tråden om Smurfen!
Personligen då, så tror jag ju att en fjädring där bärarmen och kränghämmaren går lätt i sina lagringar fungerar mycket bättre än en där grejjerna sitter stumt. Den dämpning du för in i och med att det kärvar är inte konsekvent.
The blocks arrived today and they look great
Antti: Other brands of caster blocks like Racers Edge recommend to have the locking ring to the front of the car for maximum strength, is this sommething you recommend as well?
/Dea
/Dea
Porsche 944 Turbo -90
PCS #9245
PCS #9245
Good to hear!Dea wrote:The blocks arrived today and they look great
/Dea
Sorry I haven't had time to write good instructions for installing the item. I have been working with new products and of course my new web site: http://www.9products.com.
The site is currently under construction but it's updated weekly! I've got many new products in stock that I have'nt added to the sites yet!
About installing the 9P caster block:
Install the side with the circlip and cosmetic flange faced to a-arm.
This way the load from the a-arm is being directed to the caster block body, not only the circlip.
Antti
